AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag Bravos stopped working and I hear a humming sound
Originally Posted by: Simon / APP Team  Hi. Most likely you have there a stocked drain pump. It's underneath on the right side. Remove it and check inside.
I had a 'humming noise' when water was supposed to be expelled at the end of the cycle. I took the pump out and took it apart. Turns out a bobby pin had worked its way all the way to the pump and had stopped it. Re-assembled and reinstalled the pump, tested it, and the machine works again! Thank You.
Washer Repair
