Fordmrc@gmail.com
#1 Posted : Wednesday, April 18, 2012 7:57:11 AM(UTC)
Fordmrc@gmail.com
I have a Thermador model smw272 with a built in microwave
It does not heat well. It is losing the ability to heat food at the same rate that is has in the past.
I tested the temp rise with 32oz of water and the temp rose 12 degrees in one min on high power.
Do the magnetrons lose power over time or do I have another issue.
Thanks for the help
Mike
Simon / APP Team
#2 Posted : Wednesday, April 18, 2012 9:33:20 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Yes, the magnetron may lose the power over the time.
Please provide the complete model number.
Thank you.
Simon.
Fordmrc@gmail.com
#3 Posted : Wednesday, April 18, 2012 9:46:21 AM(UTC)
Fordmrc@gmail.com
It is a Thermador SMW272P oven.
The microwave is built into the unit and upon further inspection its magnetron is a Panasonic 2M261-M32
Mike
Simon / APP Team
#4 Posted : Wednesday, April 18, 2012 10:24:05 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The microwave you have is using an inverter power board, which is no longer available.
The chance that it's the magnetron is 50/50.
Try to replace it. If it will work - you are lucky.
The good think that you can return any parts even if they been installed.
The magnetron Part number: 487757
Fordmrc@gmail.com
#5 Posted : Sunday, April 22, 2012 7:12:56 PM(UTC)
Fordmrc@gmail.com
Replaced the magnetron and the unit condition remains the same.
Time for a new microwave. The GE JEB1860SMSS has the same dimensions
as the Thermador model 11 15 157 microwave.
Thanks for the help
Mike
Fordmrc@gmail.com
#6 Posted : Sunday, April 22, 2012 9:21:26 PM(UTC)
Fordmrc@gmail.com
That's a 16 11 157 Thermador microwave I'm replacing.
Simon / APP Team
#7 Posted : Monday, April 23, 2012 10:50:59 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Guest (6)
