sethook
#1 Posted : Thursday, September 3, 2009 6:17:16 PM(UTC)
sethook
Dryer won't start...have tested most parts. Start switch continuity at 1.62K Ohms if I'm doing this right. Same reading every time. I get a reading other than 0 at M, K, but straight Ohms stays at infinity when I switch on.
Is this the problem? Is there a way to short loose wires to get her to start and confirm this bad switch?
Thanks.
sethook
#2 Posted : Friday, September 4, 2009 6:31:21 AM(UTC)
sethook
Does anyone know how to test switches with ohmeter?
