Donenrico
#1 Posted : Thursday, September 3, 2009 11:47:00 AM(UTC)
Donenrico
Usually, when I turned on the Thermostat, the oven light was on and the elements started to get hot. It's no longer the case. I am talking about the upper oven. Either the thermostat is not working, but more likely it's one of the fuses. The trouble is that I can't find where they are located. Can you help? Donenrico.
#2 Posted : Thursday, September 3, 2009 4:46:47 PM(UTC)
Check the oven clock settings. Both start and stop dial should show the same time as shown on the clock. The start button should be pushed in and the stop button should be popped out.
Check the circuit breakers for the oven.
If there is nothing wrong then I'm afraid it is time for a new oven because the thermostats and selector switch for this model are no longer available.
Here are the breakdown diagrams and Replacement parts for JENN-AIR 2550ENB | AppliancePartsPros.com
Jenn-Air Double Wall Oven No Power/Display (Oven Repair (including Ranges and Cooktops))
by vincep 8/26/2015 3:12:31 PM(UTC)
Jenn-air double wall oven - lower oven will not turn on (Oven Repair (including Ranges and Cooktops))
by hjustice 9/28/2014 11:37:55 AM(UTC)
Jenn-Air double wall oven (Oven Repair (including Ranges and Cooktops))
by Leo310 1/11/2010 3:29:44 PM(UTC)
