Thndrwhls
#1 Posted : Thursday, September 3, 2009 9:26:12 AM(UTC)
Thndrwhls
After reading some posts and speaking to a local repair shop, I think that the Hi Limit Thermo is bad, I checked continuity across both coils and the readings all came back very close to each other, set meter at 2K reading was approx 1.9 on both coils.
I checked the high limit thermo and no continuity at all. Local shop said this is most likely my problem, just wanted another opinion...
Thanks in advance,
Joe
Frank / APP Team
#2 Posted : Thursday, September 3, 2009 10:13:28 AM(UTC)
Frank / APP Team
Thanks in advance,
Joe
If the high limit is reading open, it is bad. Below is the part #. Also have a link to your model. Page 5 shows the burner breakdown.
Part number: AP4036956
Thndrwhls
#3 Posted : Thursday, September 3, 2009 10:20:33 AM(UTC)
Thndrwhls
Thanks, I did a little more research and decided that maybe I didnt observe long enough. I reattched the door and ran the cycle, burner lit ran for 3-5minutes and then shut off. After that the glow plug would glow every few minutes but no flame, let it do this three times with same result. I just want to make sure that this is the problem before I spend the money on the parts...
Thanks,
Joe
Frank / APP Team
#4 Posted : Thursday, September 3, 2009 10:38:31 AM(UTC)
Frank / APP Team
Thanks,
Joe
Glad you did some more looking. That's generally a sign of bad coils even though they checked good ohming them out. When under load they will act the way you are describing. Actually very common.
Part number: AP3094251
Thndrwhls
#5 Posted : Thursday, September 3, 2009 10:44:22 AM(UTC)
Thndrwhls
Glad I did too, thanks again for your help! Wonderfull service!!! :)
Frank / APP Team
#6 Posted : Thursday, September 3, 2009 10:54:35 AM(UTC)
Frank / APP Team
Thanks, glad we could help.
