try2fix
#1 Posted : Monday, April 16, 2012 5:48:51 AM(UTC)
try2fix
The Bake and Cancel button on the panel does not work. Is it the Membrane or Electronic panel that is gone? I have had this range for less than 3 years and very disappointed. We used the Broil and couldn't switch the oven off. Had to switch off the main fuse to shut off the oven.
Simon / APP Team
#2 Posted : Monday, April 16, 2012 2:48:05 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First get access to the control board and with power off disconnect the flex ribbon connector from the board.
Using the pencil eraser clean ribbon contacts and reinstall it back.
Plug the unit in and see if it's works.
If the problem still exists - replace the membrane assembly.
The membrane silver Part number: 316549114
Her are the breakdown diagrams and Replacement parts for Frigidaire CPGF3081KFB GAS RANGE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
kgause22
#3 Posted : Wednesday, May 21, 2014 10:32:06 AM(UTC)
kgause22
Based on your advice above I disassembled the backguard and removed the membrane. I found some discoloration on control board in the area where the controls are not functioning. Is this indication that the control board is bad??
