dadofthree
#1 Posted : Sunday, April 15, 2012 8:40:47 PM(UTC)
dadofthree
I have a Maytag Quiet Series that just turned 10 years old and it is very quiet right now, since it is not working. None of the buttons on the control panel will work. I have turned the breaker off for about 15 minutes and still nothing. I will turn it off overnight to see what happens.
So is this a control panel problem, and if so what part do I need?
I noticed that you had an item with the number AP4364914.
Is that just the cover or is that what I would need to possibly fix my problem?
#2 Posted : Monday, April 16, 2012 3:02:20 AM(UTC)
Here are your parts, includes a wiring diagram.
Replacement parts for Maytag MDB6657AWW DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
You will need a multi-meter to troubleshoot this.
If the unit is wired using a line cord check for power at the receptacle.
Check for power at the wing nuts that either attach a line cord or the house wiring to the unit.
If OK then remove power from the unit either unplug it or shut the breaker off.
Then remove the inside cover from inside the door and check that both door latch switches close when in the latched position using resistance/ohms. Bothe switches should read 0 ohms when closed.
You will see on the wiring diagram that they kill power to the control board etc. when open.
If they are OK then odds are that the control board (Item 2 in Section1) is toast
[COLOR="DarkRed"]I noticed that you had an item with the number AP4364914.
Is that just the cover or is that what I would need to possibly fix my problem?[/COLOR]
It is just the cover/panel.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Maytag dishwasher dead (Dishwasher Repair)
by archer75 1/25/2018 7:13:29 PM(UTC)
Maytag Dishwasher Dead in the Water (Dishwasher Repair)
by Mr B 2/6/2013 2:17:12 PM(UTC)
by WA_BELL1 5/31/2009 10:48:12 AM(UTC)
