rwinkless3
#1 Posted : Wednesday, September 2, 2009 1:30:30 PM(UTC)
rwinkless3
When I turn on my washer, it will fill up and thats it. If you set it to a larger load it will fill up to that level and stop working period. Thanks
I think it the timer is that correct?
applianceman
#2 Posted : Thursday, September 3, 2009 9:30:03 AM(UTC)
applianceman
The timer may be bad but it is unlikely. On some Whirlpool models the lid switch will cause not to agitate or spin. That is the first thing I would check. Hinge the control panel up and check for continuity across the lid switch with the lid closed. Clothes Washer Repair Guide
rwinkless3
#3 Posted : Thursday, September 3, 2009 6:51:31 PM(UTC)
rwinkless3
I replaced the timer because I had already ordered it. It worked for a while, so I checked the lid switch. That was the problem
thanks for all the help
