George72
#1 Posted : Saturday, January 19, 2008 6:04:43 AM(UTC)
George72
Work fine unless wife tries to scramble 2 eggs or cook 1 potatoe. Shuts down and date time needs to be reset. Does not happen if cup of water added or cook at reduced power. Wife pushing for new microwave. HELP!
#2 Posted : Saturday, January 19, 2008 5:51:00 PM(UTC)
How long it runs before shuts down?
How long it stays off?
George72
#3 Posted : Sunday, January 20, 2008 6:41:12 AM(UTC)
George72
The microwave would run for only 2 or 3 seconds after pushing the 30 second button. Clock screen would require reset. Starts immediately after clock reset. Will shut down again in seconds unless reduce power level or add a cup of water. Small quantity of food and low density seem to trigger a sensor. Problem never happens with even a half cup of water.
#4 Posted : Tuesday, January 22, 2008 12:59:16 PM(UTC)
Most likely the problem caused by the electromagnetic waves, leaking from the magnetron and interfering with the control board.
- The part number for the magnetron is AP2025937
Guest (4)
