oznib
#1 Posted : Friday, January 18, 2008 10:05:06 PM(UTC)
oznib
The original problem started with the tub not spinning durning the spin cycle. I would open the lid and hold the lid switch down with a screw driver and spin the tub by hand. The speed would slowly increase and eventually gain the proper RPM's. Now, this temporary method does not work. I don't hear the motor, the tub does not spin, and the pump does not work leaving the washer full of water. Any repair suggestions would be greatly appreciated.
#2 Posted : Saturday, January 19, 2008 12:43:50 AM(UTC)
If you hear a hum in spin, you have something clogged in the pump, just clean out. If no hum probably a bad lid switch. If slow spin, you have a bad clutch and sticking brake shoes.
Roper won't spin (Washer Repair)
by fredini 1/15/2014 9:13:56 PM(UTC)
by kellyg 6/1/2009 1:34:48 PM(UTC)
