AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Gap Between Lint Filter Outlet and Impeller fan
I have just finished replacing a drive belt and noticed that there is a gap between the felt gasget on the impeller assembly and the outlet from the lint filter. All assembly seems fine all screws lined up without any force and other than this gap (+-.25inch) everything aligns.
Do I need to worry about this or ignore it?
Originally Posted by: Nevr I have just finished replacing a drive belt and noticed that there is a gap between the felt gasget on the impeller assembly and the outlet from the lint filter. All assembly seems fine all screws lined up without any force and other than this gap (+-.25inch) everything aligns.
Thanks It was never a real tight fit. If the inside of your dryer wasn't full of lint I probably wouldn't worry about it. It is replaceable though.
Originally Posted by: Frank / APP Team It was never a real tight fit. If the inside of your dryer wasn't full of lint I probably wouldn't worry about it. It is replaceable though. Thanks Need 10 letters. Hope you are having a good summer. :)
Dryer Repair
