Is there a specific order to which the two green drum slides and the two white drum slides install on the drum bearing? For instance, if I were viewing the drum bearing from the top, would it be green, white , green, white, etc?
Thanks, Dan Bishop
Found my own answer: The green ones go at 11 and 1, the white ones go at 10 and 2. Thanks!
Groups: APP Team
Hi.
You are absolutely right.
Simon.
