sly33
#1 Posted : Tuesday, September 1, 2009 11:20:47 AM(UTC)
sly33
I'm getting an intermittant F2 flashing on touchpad and while using microwave it turns off by itself, not all the buttons work and when they do there is no tone when it is pressed.
#2 Posted : Tuesday, September 1, 2009 4:57:38 PM(UTC)
According to the Tech sheet, "F2" error code means "Touch panel failure". The suggested correction is to replace the control panel but there is a small chance for the control board to be bad as well.
If you need the correct part number for the control panel then post the color of it.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL MH1150XMS3 | AppliancePartsPros.com
