I need to replace the gas regulator/safety valve for this oven and I may also need to replace the spark module. I'm wondering if the tech sheet for this oven has been updated? I've come across other literature describing Whirlpool Direct Spark Ignition (DSI) and it shows bake and broil connections on the spark module that are reversed from what is shown on the tech sheet that came with the oven. I also had the oven serviced by Sears when it was still under warranty and I recall the technician mentioning something about those connections. Thanks for your help.
