bcringer
#1 Posted : Monday, August 31, 2009 2:45:15 PM(UTC)
bcringer
How can I confirm that the leak under the washer is from the water pump?
If it is how do I remove & install a new one?
Thanks,
Ben
sidfink43
#2 Posted : Tuesday, September 1, 2009 4:53:02 PM(UTC)
sidfink43
This video will show you how to take off the cabinet. After you do so, jumper the lid switch (stick a solid copper insulated wire with the ends exposed into the two outer holes on the plastic connector coming from the console) and operate the machine.
You will be able to see where the leak is coming from. If it is the pump, just take off the two clips and it will come right off, along with a lot of water. The only problem can be if it has leaked for a while the rust may have frozen it on the shaft, but it will come off.
Good luck.
washing machine leakes when pumping out water (Washer Repair)
by bcringer 9/1/2009 8:30:45 PM(UTC)
