:confused: I purchased the control board from app parts pro and the board that I received is different than the one that is on the stove. On the control board the four wires that connect up are in a straight line, red-li, white-NEU, blue-bake, yellow-bake. Now the control board that I received, the hookups are not in a straight line, they are all over the board and they read, line,bake,broil and R1Y101 next to it or AC N on the bottom of the connection. They tell me at app parts pro that it is the board that their records say to use. Is This board compatible? I do not want to hook it up till I know it is. Thanks Sandy
Hi Sandy,
What are the part numbers of the old and new control boards?
Verify and repost the terminal marks of the old and new control boards.
