Fan
bobhitt
#1 Posted : Monday, April 9, 2012 3:23:10 PM(UTC)
bobhitt
Hello - The freezer part of my frig is working fine it is 0 degrees. No ice build up. The opening to the frig part is wide open with no blocks. The evaporator fan is running I can hear it and see it. But there is no air being blown into the frig and it is not very cold. The fan seems to be running very fast but if it is going bad could the RPMs be down just enough to not blow air into the frig area? Could someone please help-- Thank you...
GE GTH18ECTZRWW evaporator fan issue (Refrigerator & Freezer Repair)
by snakeeyesma81 4/30/2024 4:44:21 PM(UTC)
Samsung Rs261MDWP Freezer Evap fan (Refrigerator & Freezer Repair)
by Jben04 4/29/2024 12:37:29 PM(UTC)
Frigidaire Evaporator Fan (Refrigerator & Freezer Repair)
by KevN1974 4/13/2024 11:03:34 AM(UTC)
replacement for discontinued GE convection fan motor? (Oven Repair (including Ranges and Cooktops))
by evofxdwg 4/11/2024 11:12:12 AM(UTC)
Kenmore/Whirlpool GB22DKXJW00 - evap fan replacement no ground (Refrigerator & Freezer Repair)
by DIY2024 3/24/2024 1:07:07 AM(UTC)
Monogram side-by-side not cooling - Ice builds up on Evaporator Fan (Refrigerator & Freezer Repair)
by 95ireland 3/11/2024 6:22:51 PM(UTC)
Continuously running evaporator fan (Refrigerator & Freezer Repair)
by gjgogol 2/26/2024 6:47:30 AM(UTC)
kenmore fridg 363.9532750 fan seems to run to much (Refrigerator & Freezer Repair)
by jim97 2/24/2024 7:19:40 AM(UTC)
Compressor & condenser fan not running - low voltage, start relay ok (Refrigerator & Freezer Repair)
by Guest 1/17/2024 11:51:38 AM(UTC)
Whirlpool Oven GBD307PDS7 Shuts down and Upper Blower fan does NOT work (Oven Repair (including Ranges and Cooktops))
by rswilson1844 12/3/2023 11:18:33 AM(UTC)
Whirlpool Oven Cooling Fan (Oven Repair (including Ranges and Cooktops))
by Tfastle 11/21/2023 9:59:51 AM(UTC)
LG french door refrigerator ice maker fan not working (Refrigerator & Freezer Repair)
by md5757 11/6/2023 11:27:11 AM(UTC)
Jenn-Air SVE47500B Cooling Fan Running at Low Temps (Oven Repair (including Ranges and Cooktops))
by hillridge 9/26/2023 9:04:30 AM(UTC)
GE Monogram ZV800SJ1SS Reduced Fan Speed (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 8/28/2023 2:09:18 PM(UTC)
Need to test Condenser Fan motor on GE Monogram (Refrigerator & Freezer Repair)
by Rmr882 8/25/2023 8:01:36 PM(UTC)
