I have a Whirlpool Ultimate Care II Washer and it does not drain the water. I put the dial to spin cycle and it does nothing. I put it on rinse and when it gets to the spin cycle it fills while it is in the spin cycle. I have the drain hose in the right position.... do you have any suggestions ??? Thanks in Advance :)
Originally Posted by: richappy Does it agitate? I do not think it is....the drum spins and looks like it wants to drain, however, water keeps pouring into the washer. I will check to see if the washer agitates
