2 Pages<12
HenryTheNoodle
#11 Posted : Thursday, September 24, 2009 11:32:29 AM(UTC)
HenryTheNoodle
Groups ready for retrieval: Registered
I do have the clip, it just doesn't do much. But even if I hold the ribbon secure with my hand, I still don't get most of the right side of the touch controls to work.
#12 Posted : Thursday, September 24, 2009 1:13:31 PM(UTC)
Sounds like the membrane switch has gone bad as well. Unfortunately there is no way to check it instrumentally and the part is not cheap. If you need the correct part number then post the color of the key panel.
HenryTheNoodle
#13 Posted : Thursday, September 24, 2009 1:21:56 PM(UTC)
HenryTheNoodle
It's black.
#14 Posted : Thursday, September 24, 2009 9:30:03 PM(UTC)
The black key pad Part number: AP4362220
HenryTheNoodle
#15 Posted : Thursday, December 24, 2009 6:16:39 AM(UTC)
HenryTheNoodle
I'm all back up and running now, thanks for the help Gene.
One side effect though is that the over seems to run hotter than before. Things always gook several minutes faster than recommended on the package for instance. I was thinking the cavity size setting might be a problem, but I don't get any errors. Any other thoughts?
#16 Posted : Friday, December 25, 2009 8:57:07 PM(UTC)
You are welcome.
Your oven is 30" width and the control board comes preset for 30", so you do not have to do any cavity size adjustment.
You can adjust the oven temperature as described in the Owners manual (page 6).
Merry Christmas and Happy New year!
2 Pages<12
