I have a Whirlpool washer that won't go beyond wash in any cycle. Replaced timer with no luck. Checked the Direct Drive Coupling, Looks good. Both hi & lo speeds work but as soon as it goes to pump out, washer just stops, everything. Any suggestions ?
Is your lid switch operating O.K.?:confused:
:) Problem fixed, it was the lid switch. Busted open, I'm told from slamming lid. Thanks for advise, Bentwrench1999
