AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer heats but there appears to be not air flow
Dryer heats and turns, but the there appears to be no air movement/suction.
Open it up and check out the blower to see if it is operating correctly, then clean out the vent area from the lint filter through the dryer and all the way through the outside. Make sure the air intake area is clear.
If you need additional info, please post your full model number.
Good luck.
Dryer Repair
