Icemaker does not get water: however we do get water from dispenser. Optic blinks whether door open or closed. First sign of problem was lots of water on the floor. MotorModl replaced 2007 and Relay Overload replaced 2006. Help!
Quote:...Optic blinks whether door open or closed... If the LED blinks with the flopper door on the left closed then the optics failed and both boards have to be replaced. Also make sure the water feeding tube into the ice maker is not frozen. - The refrigerator PC board kit Part number: AP3137510
