E03 error on Candy ACS 1040 said "no water evacuation from a drum" 1) all tubes were checked - no garbage in it 2) drain pump was replaced - no effect/ the same E03 error 3) water input was OK, water level sensor (pressostat) works (no gluing in @full chamber@ state) 4) all wires "pressostat-CPU" and "CPU-drain pump" were inspected.
No idea! Will somebody please help to repair this?
Well, today I've measured the AV voltage between C-terminal (blue wire came direct from N-connector of ZW-power filter) and P-terminal (yellow wire or GIALLO on the scheme attached). It was app. 5-8 V AC in "EMPTY drum" and 220 VAC in "above First level". As for S-terminal (red wire run to 1 pin of PN connector on CommandModule 41009801 017938223 41009111 VS C48 ICA INT. 06/10/04 000364479 OP. 28) - voltage changes from 0.08 in "Below second level" into 110 VAC in "Above second level". If you drop out red wire connector from pressostat, water income doesn't stop i can go over vessel. The question is "What should I check in Electronic module to ensure the cause of E03 eror hides in it or in pressostat? What should I replace?" Vvlad attached the following image(s):
Thanx for advices. Now I have another pressostat ( 04=06 7670001 12NC 461971077021 65/40 300 ). It has four(4) pins 11, 12, 14 и 16. Tell me please if any khows, is it compatible with Candy ACS 1040 (31145105 0447 2344)? If so, am I write right in my guess of blue wire should be connected into 11, yellow -to 14 , and red -(from 1 lamelle PN el.module) - at 16? Can I leave 12 free in air (unfortunately its very hard to fix it with hose from drum, much better join the hose with tube:confused: )?? I've noticed, module after 2 lamelle in group of PN goes through 4 resistors into artefact rectangular (may be relay?). What can it be? Forgive, please my Ignorance, Up now I dealth with biochemical analyzers, X-ray, US, CT and mass-spectrometry. Vvlad attached the following image(s):
Artefact is a capacitor, new relay didn't help - shows the same error 03. What about scheme for this module? If anybody has , please, share it in vldu at itaec dot ru
