Oven and Broiler ignite then shut off after 2 seconds
What part should I be getting to solve this problem
Most likely the problem is a bad spark module. - The part number for the spark module is AP3672576 Here are the break down diagrams for the Whirlpool range Model SF367LEKQ0Gene.
Did u replace and or what fixed this problem? My Whirlpool is doing the same thing I think. The gas will start from the igniter but it shuts off when u release the start button.
