The heavy and normal cycle lights and the cancel light is flashing. I can' get it to start. Any suggestions?
Groups: APP Team
Hi.
Remove the control panel, remove the ribbon connector from the board.
Using the pencil eraser clean the ribbon contacts. Reconnect and power up the unit.
If it still doesn't work - replace the control panel.
Please, provide the color for correct part number.
Thank you.
Simon.
