Kathi callaway
#1 Posted : Monday, April 2, 2012 6:01:32 AM(UTC)
Kathi callaway
Help, my dishwasher won't drain. I have no idea how to get it apart to clean the drain or check anything that might be suggested:( If anyone has any ideas to help me I would appreciate it. Getting desperate!!!
ApplianceJunk
#2 Posted : Monday, April 2, 2012 6:56:09 AM(UTC)
ApplianceJunk
Can you hear the drain pump running when it should be draining?
If it sounds like the pump is running the first thing I would do is remove the drain hose from under the sink, maybe it connects to a food disposal and just look into the hose and connection for anything blocking the flow.
Also check the drain hose for kinks. If the drain hose has a splice or other connection anyway in the hose that is another spot they like to plug up.
If you can't hear the drain pump running I would check it with a multimeter for continuity. If it has no continuity then you need to replace the drain pump.
