LinRH
#1 Posted : Tuesday, August 25, 2009 2:48:00 PM(UTC)
LinRH
My Performa washer started smoking the other day and shut off. I called the repairman and he said it was the motor and it will cost $329.00 to put a new one in. When he turned on the washer everything was working and it still is. Could it really be the motor that is bad even though it still runs? thanks!
sidfink43
#2 Posted : Thursday, August 27, 2009 12:04:03 PM(UTC)
sidfink43
These motors have overload protection, so they should be fine. It is possible there was hangup somewhere in the machine (basket, transmission, pump ???) that worked itself loose.
If the machine is working, keep going, let us know if you have a problem, but it is doubtful the motor needs replacing.
LinRH
#3 Posted : Thursday, August 27, 2009 12:20:15 PM(UTC)
LinRH
Thanks so much for the information. It does seem like it runs just fine.
Washing machine motor buzzes depending on motor shaft position (Washer Repair)
by fixitboy 4/26/2013 1:59:09 PM(UTC)
