REPOST:confused::confused::confused:
I looked at all the answers to this same question, but they were all for double ovens, and this is a single oven and the person in Customer Service said that there is no "Thermal Fuse" for this oven Model. Please Respond.
We have a Whirlpool Gold, Accubake system. Tried the self-clean a while ago and toward the end of the cycle the oven just shut down. The door is still locked and none of the control panel button's work. The range works fine. I tried the other suggestions on this forum, but they were all for the Double oven wall units. I looked at all the diagrams for this model and pulled apart the control panel, but did not see the thermal fuse. Please suggest away.
THanks for your prompt response.
Quote:Customer Service said that there is no "Thermal Fuse" for this oven Model. There is a " thermostat" and a " thermal cut-out" listed for your model ( items # 14 and 15 in the 'Cooktop' illustration). Either of those might stop power from getting to the electronic control depending on how they are wired. I'm afraid I do not know where they're located on your specific model. Failing that, if power WAS getting to the electronic control but it was not functioning at all, the control would likely be defective. If power was NOT even making it to the control, the problem would be in the wiring or wiring components... somewhere. JMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
