alcan
#1 Posted : Tuesday, August 25, 2009 6:26:35 AM(UTC)
alcan
Fridge all of a sudden would not get cold even with it set on coldest. Then the freezer was not freezing and basically turned into the fridge. The ice that had been there started melting. Took off back of freezer wall and the entire thing was frozen solid with ice. I melted the ice with a blow dryer and magically the fridge was cold again and the freezer was freezing again. However this only lasted a few days and it started doing the same old stuff. I would greatly appreciate the help as I do not have the money right now to pay someone to fix it.
Ken
DeoWolf
#2 Posted : Tuesday, August 25, 2009 6:36:51 AM(UTC)
DeoWolf
Could be a Defrost control issue...I am currently having the same issue...however, I found the part...at only $30.00, but,...and this is the part thats driving me nuts...I don't know where it is in the freezer...But, if you know what your looking for, it may assist you. Good luck.
alcan
#3 Posted : Tuesday, August 25, 2009 6:44:16 AM(UTC)
alcan
I call tech he say seneor have to change.
