not sure what the issue is but my roommate turned the oven on and it burned for several hours and I believe he the oven door was left open + using it as a source of heat when my boiler pilot went out..... Is this a thermostat issue or an igniter... thanks Tim
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Originally Posted by: TFitz  not sure what the issue is but my roommate turned the oven on and it burned for several hours and I believe he the oven door was left open + using it as a source of heat when my boiler pilot went out..... Is this a thermostat issue or an igniter... thanks Tim Is this a thermostat problem or an igniter issue
