Replacement parts for Whirlpool LEC6848AN1 ELECTRIC DRYER | AppliancePartsPros.comSee the attachment for the wiring diagram.
. I have replaced the thermal fuse, drive motor, cycling thermostat, thermal cut-off kit and door switch.
The cycling thermostat and thermal cut-off have no effect on the motor starting.
Here is the start circuit for timed dry.
NEUTRAL , DOOR SWITCH D1/D2 , TIMER SWITCH 4 T/W , motor's centrifugal switch , START and MAIN motor windings , THERMAL FUSE , PUSH TO START RELAY R2/R1 , timer contacts BU/BK , L1 120 volts.
Since you have replaced a lot of the parts all that is left is the timer contacts and the start relay or you have a bad connection in the circuit.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
