My washer occasionally does not spin after the rinse cycle and often there is dirt in the bottom.
Hi Kathy I think you need to do two things. 1. Check the lid switch. This site will show you how to access it. 2. After you take off the front, take off the pump (water will gush out, be prepared) and clean out the drain hoses. In fact, stick a hose in the tub and with the pump off wash it out real good (have a bucket to catch the water) Kenmore top loader blues (SublimeMasterJW's Appliance Advice)Good luck
