I replacer the tub support and the motor and control board. Got my washer all back together and now it leaks. Took the outer tub close out off front and cleaned that seal and replaced close out. Ran with front panel off empty and had no leaks. put all back together and when we did laundry it still leaks. only seems to happen when loaded. Any tips?
