ngavrelos
#1 Posted : Sunday, August 23, 2009 1:08:06 PM(UTC)
ngavrelos
washer fills,agitates,won't rinse or drain.lid switch seems ok. Timer will just keep going?
applianceman
#2 Posted : Monday, August 24, 2009 7:54:46 AM(UTC)
applianceman
If you turn the timer to spin and turn it on and you hear the pump motor try to work but the water doesn’t pump out, there may be something hung in the pump. Remove all the water then remove the black hose off the top of the pump. Once done you can feel inside the pump for obstructions. Note be ready for water when you remove that hose because you will never dip all the water out. Clothes Washer Repair Guide
