My clean light keeps blinking 7 times on my whirlpool dishwasher model # GU2400XTPB3. I've reset it using the Normal wash/ heat dry sequence many times and it still will not complete a cycle. I looked under the kick plate but there was no tech sheet there. Is there somewhere i can get a tech sheet?
Try heated dry, normal sequence. If still no go, you have a heater fault, either a thermostat, or broken heater.
