john potts
#1 Posted : Friday, March 30, 2012 9:47:50 AM(UTC)
john potts
exessive ice/water in freezer that will melt down into the refrig causing a real flood. The ice maker has been removed and water disconnected, so that is not the source. Gaskets are air-tight. Temp settings are both at recommended (3) setting. Any idea where all the water is coming from?
John
Joe / APP Team
#2 Posted : Friday, March 30, 2012 10:20:09 AM(UTC)
Joe / APP Team
John
John, You'll need to remove the evaporator cover( freezer rear wall) and check the defrost drain trough, and tube for a blockage, or freeze over. Some towels, hot water and a "Turkey Baster" works pretty good, if it is.
Good Luck and Thanks,
