put new thermastat on work fine defrost like it should nowit is getting to cold in fridge it was turned down to 3 and now i have turned it down to 2 any help with this problem:mad:
What is the temperature in the freezer?
thanks gene i got it it was the control panel not on right where the air comes form the damper every thing seems to be working fine now
I'm glad you were able to fix it.
