Hi I have a GE hydrowave that is noisy when it is in the mode where it is spinning real fast. Any suggestions?
Groups: Joined: 12/1/2008(UTC) Posts: 0
Hello. The roaring sound is most likely coming from the tub bearing where the mode shifter comes thru the tub seal this can be replaced, Thank you Part number: AP2045289
