stevemac51
#1 Posted : Thursday, March 29, 2012 2:24:06 PM(UTC)
stevemac51
I'm Starting A New Post Because Of The Wrong Model Number I Used Previously. When I Use This Model # To Find Parts At This Website, It Brings Up The Correct Parts Pages. In Your Last Post You Said Since I Changed The Switch And That Didn't Fix It Then The Element Needs To Be Changed.
Just To Repeat My Problem, I Have A Ge Stovetop That Has A Glass Top. There Is One Burner That Has A Small And Large Element . The Small Works Fine But I Get Nothing From The Large One. I Changed The Switch For This Burner But Still Nothing.
Do You Still Think It Is The Element That Needs Replacing?
#2 Posted : Thursday, March 29, 2012 3:08:43 PM(UTC)
Originally Posted by: stevemac51 Go to Quoted Post
...Do You Still Think It Is The Element That Needs Replacing?...
Yes, I do. Especially if there is nothing wrong with the wires. I'm glad you were able to find the correct model number.
- The dual heating element Part number: AP2027786
ge stove top double burner, large side not working (Oven Repair (including Ranges and Cooktops))
by stevemac51 3/16/2012 12:31:05 PM(UTC)
