Want to check defrost kit , cant find the location. also need to know how many thermostate are involved in compressor circuit.Please help Thanks Imran
Groups: APP Team
Hi. "Compressor wont start". Is any of the fan motors running? If there is only lights on, check cold control, it's located in fresh food section top left. First tap on it with screwdriver's butt. Kicks on - replace it. Still not working, take it out and with one wire off check for continuity between two contacts. Open - replace the cold control, closed - replace the ADC (defrost control) located next to the cold control. The cold control Part number: AP4012576
The ADC Part number: AP4014734
There is only one thermostat/cold control in compressor circuit. Good luck. Post the results. Simon.
Thankyou very much for your help. Both fans were running, overload/relay attached to compressor was loose and caused burnt and it was happen when i was cleaning condensor a month ago with long brush and holding clip for relay came off. Great site with great help. Thanks again.
Groups: APP Team
You are very welcome.
I'm glad you solved the problem.
Simon.
