RandyH23
#1 Posted : Friday, August 21, 2009 11:53:31 AM(UTC)
RandyH23
Hello, I have a model electric dryer. The clothes seem to get caught by the drum when you open the door they are hanging or stuck, usually burned or marked by rust or even holes. From what I have read there is a seal that is suppose to go there? What steps are needed to replace this seal? The drum seems almost loose as if you open the regular door you can reach in and actually push up on the drum slightly. Thank you so much
sidfink43
#2 Posted : Sunday, August 23, 2009 9:50:18 AM(UTC)
sidfink43
I would say that as a first step you should replace the rear bearing. Here is the kit to do that.
Part number: AP2142648
When you do this you will have to take out the drum, and you can then see if the front felt or other parts will need replacing.
RandyH23
#3 Posted: : Sunday, August 23, 2009 5:09:06 PM(UTC)
RandyH23
Is there a diagram or how to located on here somehwhere that shows how to replace this or do the repair? Thanks for your assistance!
sidfink43
#4 Posted : Monday, August 24, 2009 4:56:38 AM(UTC)
sidfink43
If you will click on your model number you will be taken to exploded views of your machine. You start by inserting a screw driver in the gaps between the front and the top at the edges to release clips. This will allow you to flip up the top. You cn then take off the front, remove the drum from the machine and go from there.
Good luck.
RandyH23
#5 Posted : Monday, August 24, 2009 8:24:50 AM(UTC)
RandyH23
Good luck.
Thanks I appreciate all the info and help
Dryer damaging clothes? (Dryer Repair)
by ES13Raven 3/24/2013 10:51:18 AM(UTC)
Frigidaire dryer damaging clothes (Dryer Repair)
by oldmkeb 7/12/2010 10:14:34 AM(UTC)
Stackable dryer damaging clothes (Dryer Repair)
by cbssml 6/2/2008 6:07:09 PM(UTC)
