Jolangl2
#1 Posted : Friday, August 21, 2009 11:32:36 AM(UTC)
Jolangl2
[FONT="Lucida Sans Unicode"]My kenmore won't take in water, either on rinse or from start to finish.[/FONT]
#2 Posted : Friday, August 21, 2009 1:57:45 PM(UTC)
Remove the toe panel, remove the wires from the water valve solenoid and check the solenoid for continuity. Check for 120 VAC between these wires while the timer calls for water. If there is proper voltage then replace the water valve.
- The water valve Part number: AP3010773
