guy30000
#1 Posted : Friday, August 21, 2009 8:36:34 AM(UTC)
guy30000
My Kenmore Series 70 dryer will start sometimes. If I leave it alone for awhile it will start and run for a few minutes. If I start and stop it a few times in a row I can usually get it to start 3-5 times before it stops working. Usually before it stops working It will hum as I hold the start button then that sound stops and i have to give it some time befor I can do this all again. I believe this means the moters bad. I've tested the start switch with a multimeter , door switch and what I believe to be is the thermal fuse, and they all seam ok.
sidfink43
#2 Posted : Sunday, August 23, 2009 9:45:18 AM(UTC)
sidfink43
If this is a gas dryer, check out the gas components, otherwise it sounds like a motor failure.
