dostroski
#1 Posted : Thursday, August 20, 2009 4:46:55 PM(UTC)
dostroski
When the dryer starts it makes a very loud squeeking noise for the first 3-4 revolutions of the drum and then the noise stops. The dryer seems to work fine but the noise is begining to last longer when the dryer starts. From reading this forum it seems that it could be the belt, rollers, etc. Is there a way to identify problem so I can order correct part. Thanks in Advance.
guy30000
#2 Posted : Friday, August 21, 2009 8:50:59 AM(UTC)
guy30000
Sounds like the belt is slipping. Check it out and if so replace it.
