when I first start my maytag gas dryer it starts up fine then in about 2 or 3 minutes the gas flame turns off. I would appreciate any help and advice anyone could provide.
You have been a member since:: 8/20/2009(UTC) Posts: 2
Originally Posted by: yahshua when I first start my maytag gas dryer it starts up fine then in about 2 or 3 minutes the gas flame turns off. I would appreciate any help and advice anyone could provide. could be not moving the air check clean lint screen and below check blower action to rear of dryer... yes? see if the air is flowing well to the outdoors. clean duct unplug and clean inside around gas burner grace and peace, jon
The air seems to be moving fine. I cleaned and checked lint screen as well as air flow outside. I'll unplug and clean inside around gas burner and try again. I had a reply stating it was a bad gas valve coils.
