26.2OrNothing
#1 Posted : Tuesday, March 27, 2012 3:57:33 PM(UTC)
26.2OrNothing
I am having issues with the top dish rack lower spray arm (number 16 on the attached link). It will not spray water to the upper dishes. The top arm on the machine works and the lower rack dishes do come clean. I am suspecting the Docking Station but i would like to see if there may me another possibility. Any suggestion would be greatly appreciated.
Mike
26.2OrNothing
http://www.appliancepartspros.c...ect/3/l/2/3l26s5rdf0.gif
#2 Posted : Wednesday, March 28, 2012 2:10:43 AM(UTC)
Could be a low fill.
A common problem is the unit not filling with enough water.
Most units fill to just under the heating element.
This can be checked by adding a couple quarts of water after each fill during a cycle. If it now washes OK then check the fill valve.
Just be careful to not overfill it.
Often if the fill is low you will also hear a growling sound because the pump will cavitate (suck in air).
The most common cause is a dirty screen filter on the input side of the fill valve. Remove the valve from the unit and clean/check the filter.
Do not permanently remove it from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
If it still does not fill correctly I would replace the fill valve.
PS: Be sure to shut off the power and the water supply to the unit. Have paper towels etc. handy to wipe up any spilled water. Get a small pan/bowl etc. that will fit under the valve then loosen the input water line let it drip into the container emptying it as necessary. This will minimize the amount of water spilled.
Also could be dirty filters or something impeding the pump.
Open the pump up and check the filters and that the impeller and chopper are clear.
Following is a manual which should help.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=231
Check the distribution assembly.
Click on the picture of Item 3 in Section 7 of the parts and a new page will open with more views and info.
Jenn Air Dishwasher soap dispenser door wont open (Dishwasher Repair)
by Guest 10/22/2021 5:22:26 AM(UTC)
Jenn Air Dishwasher does not drain completely (Dishwasher Repair)
by jjdoc 6/26/2012 11:41:48 AM(UTC)
Jenn Air Dishwasher Control Panel (Dishwasher Repair)
by ackress 5/9/2011 3:51:04 AM(UTC)
Jenn Air Dishwasher Leaks (Dishwasher Repair)
by BIBS 10/28/2009 7:16:24 AM(UTC)
jenn air dishwasher (Dishwasher Repair)
by armor 5/29/2009 11:33:15 AM(UTC)
Jenn Air Dishwasher rack assembly (Dishwasher Repair)
by Lobelia 8/9/2008 6:50:02 AM(UTC)
my jenn air dishwasher won't drain (Dishwasher Repair)
by jimmyribar 4/30/2008 1:14:34 PM(UTC)
Jenn Air Dishwasher wont fill (Dishwasher Repair)
by Sean 4/30/2008 10:25:12 AM(UTC)
