sanantonio6355
#1 Posted : 16 years ago
sanantonio6355
My garbage disposal was jammed with a bone. I removed the bone but now it hums but the blades will not spin. There is no reset button on this model. It did this once beforenad was broken for a couple of weeks and fixed itself (when the repairman showed up) but I don't know how.
magician59
#2 Posted : 16 years ago
magician59
Try to move it physically with a 1/4 inch hex wrench, right in the center on the bottom.[COLOR="Red"] Unplug it first[/COLOR]. If that fails, try to move it with a broom handle or large screwdriver from above. If it moves freely, and there are no loose wires at the connection, replace it. (1/2 HP or larger will handle those bones.)
sanantonio6355
#3 Posted : 16 years ago
sanantonio6355
Thanks! Will give it a try!
