kid154
#1 Posted : Thursday, August 20, 2009 7:18:00 AM(UTC)
kid154
diswasher will not pump out water replaced motor pump mechanism could it be the dual pump that is no good
#2 Posted : Thursday, August 20, 2009 3:57:43 PM(UTC)
Remove the filter frame (#543 on the diagram), unscrew and check the piston & nut assembly (#564).
- The piston & nut assembly Part number: AP2617344
