slipperychic
#1 Posted : Thursday, August 20, 2009 3:32:06 AM(UTC)
slipperychic
Rank:: Member
I have a window unit that is freezing up. What could the problem be?
gibs
#2 Posted : Sunday, August 23, 2009 7:20:28 PM(UTC)
gibs
wihout alot of info hard to pinpoint a problem. is your filter clean,also is there air flow coming out of the unit. will the unit shut off it your turn the temp down. need a little more info.
SublimeMasterJW
#3 Posted : Monday, August 31, 2009 8:36:02 AM(UTC)
SublimeMasterJW
If the unit is freezing up then the coils are probably dirty. So clean em up with a nice cooling coil cleaner. Ace hardware has a very nice product called foaming cooling coil cleaner. Another thing could be the thermostat is bad. Do this simple test: Dip the probe into a glass of ice water. This will make the compressor shut down. If the compressor continues to run then replace the thermostat. FYI: If the compressor runs constantly then sooner or later the whole ac will ice up.
