Michael Larkin
#1 Posted : Wednesday, August 19, 2009 7:04:05 PM(UTC)
Michael Larkin
The dryer is running very hot on all cycles. It blew thermal fuse. I cleaned out vent from dryer to outside completely. Put in new fuse; still running hot. Setting on timer won't even move. It runs in the same place until I turn it off. Thermal fuse blew a second time. Is there a thermostat issue? Is it the timer control? I would like some idea of what to look for since I have been told it could be about 4 different things.:confused:
sidfink43
#2 Posted: : Thursday, August 20, 2009 3:34:19 PM(UTC)
sidfink43
It could be 4 things, heck it could even be more than 4 things but I would try this thermostat first.
Part number: AP3131939
Also, I know you cleaned it out, but did you take the cover off of the blower and clean it out from the top to bottom. (yeah, you probably did but check it anyway)
Good luck.
